How to connect differential probe bnc pin and ground pin to oscilloscope. I know how to connect differentil probe bnc to oscilloscope channel but how to connect ground pin of differential probe to oscilloscope?
The ground is already connected through BNC cable. A ground pin at the probe side (present in some low voltage probes) may be connected to an isolated circuit under test to reduce common mode voltage. Which particular probe are you asking about?
The differential that i use has a auxillary ground pin with bnc pin. So i connected bnc pin to channel of the scope. And how to connect ground pin to scope?
