Die size from def file
chanducs24
hi
tell me how to fix die size in encounter using def file?where can i find the die size in def file.my def file has die area (0 0) (1130000 400000). so in encounter, whats the value i have to fix for die size?
Thanks,
chandra.
Def file contains this line "UNITS DISTANCE MICRONS 2000 ;" to indicate by how much you should divide your value.
---------- Post added at 12:56 ---------- Previous post was at 12:55 ----------
this means 1um = 2000 units
