[SOLVED] Did Someone use TINA Electronics Simulator and PCB Designer
tahir4awan
Full Member level 4
Germany
I used this software which claims real time simulation but using microcontrollers in this software is really a difficult task. I did every thing to make microcontroller work but I failed. Did someone used this software for microcontroller simulation?
Hey buddy...
U should use Proteus VSM...If u want to Simulate uC...
Its better than TINA
I previously used TINA Pro Indusrial Version...then later switched to Proteus...
Regards.
Sidy.
Yes I use Proteus but I like TINA tools management and very simple.
Do you how to disable default clock source and supply voltage of microcontroller in Proteus. Because proteus can simulate without external clock source and voltage source.
