mshh
Full Member level 6
I want to read humidity and temperature from sensor DH11.
I used this code from this page https://electronicwings.com/avr-atmega/dht11-sensor-interfacing-with-atmega16-32
there is error in this program
and I want to modify it using codevision
Error: C:\Users\mado\Desktop\egg\clk.c(10): '(' expected
as in the pic
#include <mega16.h>
#include <stdlib.h>
#include <stdio.h>
#include <alcd.h>
#include <delay.h>
#define DHT11_PIN 6
uint8_t c=0,I_RH,D_RH,I_Temp,D_Temp,CheckSum;
void Request() /* Microcontroller send start pulse/request */
DDRD |= (1<<DHT11_PIN);
PORTD &= ~(1<<DHT11_PIN); /* set to low pin */
delay_ms(20); /* wait for 20ms */
PORTD |= (1<<DHT11_PIN); /* set to high pin */
void Response() /* receive response from DHT11 */
DDRD &= ~(1<<DHT11_PIN);
while(PIND & (1<<DHT11_PIN));
while((PIND & (1<<DHT11_PIN))==0);
uint8_t Receive_data() /* receive data */
for (int q=0; q<8; q++)
while((PIND & (1<<DHT11_PIN)) == 0); /* check received bit 0 or 1 */
delay_us(30);
if(PIND & (1<<DHT11_PIN))/* if high pulse is greater than 30ms */
c = (c<<1)|(0x01); /* then its logic HIGH */
else /* otherwise its logic LOW */
c = (c<<1);
return c;
int main(void)
char data[5];
lcd_init(16); /* Initialize LCD */
lcd_clear(); /* Clear LCD */
lcd_gotoxy(0,0); /* Enter column and row position */
lcd_putsf("Humidity =");
lcd_gotoxy(0,1);
lcd_putsf("Temp = ");
while(1)
Request(); /* send start pulse */
Response(); /* receive response */
I_RH=Receive_data(); /* store first eight bit in I_RH */
D_RH=Receive_data(); /* store next eight bit in D_RH */
I_Temp=Receive_data(); /* store next eight bit in I_Temp */
D_Temp=Receive_data(); /* store next eight bit in D_Temp */
CheckSum=Receive_data();/* store next eight bit in CheckSum */
if ((I_RH + D_RH + I_Temp + D_Temp) != CheckSum)
lcd_gotoxy(0,0);
lcd_putsf("Error");
else
itoa(I_RH,data,10);
lcd_gotoxy(11,0);
lcd_putsf(data);
lcd_putsf(".");
itoa(D_RH,data,10);
lcd_putsf(data);
lcd_putsf("%");
itoa(I_Temp,data,10);
lcd_gotoxy(6,1);
lcd_putsf(data);
lcd_putsf(".");
itoa(D_Temp,data,10);
lcd_putsf(data);
lcddata(0xDF);
lcd_putsf("C ");
itoa(CheckSum,data,10);
lcd_print(data);
lcd_print(" ");
delay_ms(10);
as in the pic
