May 13, 2009 #1 A amar.reddy4020 Newbie level 3 Joined Jan 12, 2009 Messages 3 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,300 dft lssd Hi friends, I got the S1-error after when i run post-DFT drc. I wrote out my net list then i found that my SN pin of latch which is connected to permanent-1 in functional mode is now connected to SCLK (Scan Slave Clock). Can anyone help me in debugging this. The scan type is LSSD. Thanks in advance
May 24, 2009 #2 wizard Member level 3 Joined Mar 30, 2002 Messages 66 Helped 8 Reputation 16 Reaction score 5 Trophy points 1,288 Location China Mainland Activity points 421 Re: DFT with LSSD cells You are using DC to do this? What is S1? Sorry I don't have time to look up that in manual. Because most design are DFF based, I doubt the tool's matrurity on LSSD if you have set configurations correctly according to manual. amar.reddy4020 said: Hi friends, I got the S1-error after when i run post-DFT drc. I wrote out my net list then i found that my SN pin of latch which is connected to permanent-1 in functional mode is now connected to SCLK (Scan Slave Clock). Can anyone help me in debugging this. The scan type is LSSD. Thanks in advance Click to expand...
May 25, 2009 #3 A amar.reddy4020 Newbie level 3 Joined Jan 12, 2009 Messages 3 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,300 Re: DFT with LSSD cells S1: is scan chain blockage after (cell number is scan chain ) cells. I'm using dc to do this and my protocol is perfect. I hope there is problem with LSSD State table in the Library.
May 25, 2009 #4 S sunilbudumuru Full Member level 2 Joined Oct 8, 2008 Messages 123 Helped 41 Reputation 82 Reaction score 19 Trophy points 1,298 Location Hyderabad Activity points 2,219 DFT with LSSD cells checkout this http://www.asic-dft.com/Level%20Sensitive%20Scan%20Design%20(LSSD)%20Style.html
