Warning: There were 630 faultable pins lost due to tied gate optimizations. (M126)
There were 129015 primitives and 2434 faultable pins removed during model optimizations
Warning: Rule B7 (undriven module output pin) was violated 605 times.
Warning: Rule B8 (unconnected module input pin) was violated 1090 times.
Warning: Rule B9 (undriven module internal net) was violated 201 times.
Warning: Rule B10 (unconnected module internal net) was violated 754 times.
Warning: Rule N16 (overspecified UDP) was violated 1 times.
Warning: Rule N23 (inconsistent UDP) was violated 1 times
run_atpg basic_scan_only
* NOTICE: The following DRC violations were previously *
* encountered. The presence of these violations is an *
* indicator that it is possible that the ATPG patterns *
* created during this process may fail in simulation. *
* Rules: N23 *
