DFR200 Compaq-Identix Fingerprint Sensor SDK Manual Needed
real_tr
Member level 3
Turkiye
sensor identix dfr 200
Hi to all,
I buy a fingerprint sensor name compaq fingerprint scanner and comes with identix biologon software
but i want to use this scanner with my program
how can i do that,
I need an SDK developers manual for this purpose
Anyone have??
i download an SDK program from identix web site -> checkdfr.exe
it uses 3 dll files
dfrdrv.dll -> DFR200 interface library
itio32.dll -> Image input/output library
itf32.dll -> Framegrabber interface library
how can i use these dlls if cannot find any sdk manual
(i know delphi, c and c++ langıages)
Please Help...
biologon download sdk
Hi - remember the parallel-port type of web-cameras? The DFR-200 uses the same chip as many of those old "quick-cams". When I get back to work Monday I'll tell you the exact chip and where to get the datasheet.
:wink:
identix c libraries and dlls
any other???
dfr-200 sdk
The Identix DFR-200 uses the ST Microelectronics "VV5404" monochrome camara chip. If you can get the datasheet from ST, it will tell you how to control the interface and timing.
The DFR-200 has a 10-pin in-line connector on the module. It has the following signals:
1 = SCL (I2C control interface CLK signal)
2 = SDA (I2C control interface DATA signal)
3 = DC3 (camera data MSB)
4 = DC2 (camera date)
5 = DC1 (camera data)
6 = DC0 (camera data LSB)
7 = CLC (camara data clock)
8 = +5V (90mA max)
9 = GND
10 = Shield-GND (connected to GND on module PCB)
Enjoy!
identix sdk
thanx
any other???
any reference or smt. help
How much it cost ?
How much it cost ?
Re: DFR200 Compaq-Identix Fingerprint Sensor SDK Manual Need
Anybody has more information about the sdk for the dfr-200 fingerprint scanner. Library details for the dlls that come with the device, sdk, etc.
Or may be a library or ocx control that can use the device?
Thanks very much.
Eli
