Device which resistance increases with the current increase
awan
Los Angeles
current sources
any device whose resistance increases with the increase in current
Al Farouk
Full Member level 4
Egypt
Re: current sources
the PTC (positive temperatue coefficient) it is a resistance that its value increase with temperature. and as power dissipation in resistance = I*I*R(I2*R) so as current increase temperature increase and so the resisatnce value
rudane
Member level 1
Re: current sources
Even your basic piece of copper wire has a PTC (Positive temperature coefficient). As the current through the copper increases there are more free ions moving. These free ions impede the current flow and increase the resistance of the wire.
Fom
Advanced Member level 2
Taiwan
Re: current sources
Any drain of MOS transistor with gate DC voltage>Vth has this feature.
kohtwe
Junior Member level 2
Re: current sources
because positive temperature coefficient
test_out
current sources
What do you mean by resistance? You mean the input or output impedance?
Andrew8611
Member level 1
Re: current sources
I think that any material with a PTC (Possitive temperature coeficient) like cooper, can change their resistance with the heat making it higher than normal.
