RFdata
Newbie level 6
c++ serial port
Hi, i´m trying to interface serial port using DEV c++, when i used an old Dos compiler everything was easy simply use outport and inport, now for windows it´s very different, but I sussefull put data on serial out, the problem is that I can´t read data from RX pin.
It only receives the data A that is the output, but there is no loop back from the TX to RX on the serial pins, so where it get that value?
I using this code
Any help is welcome
Tanks
I using this code
Any help is welcome
Tanks
Code C++ - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 #include <conio.h> #include <stdio.h> #include <windows.h> #include <bios.h> // Flow control flags #define FC_DTRDSR 0x01 #define FC_RTSCTS 0x02 #define FC_XONXOFF 0x04 using namespace std; // variables used with the com <strong class="highlight">port[/b] BOOL bPortReady; DCB dcb; COMMTIMEOUTS CommTimeouts; BOOL bWriteRC; BOOL bReadRC; DWORD iBytesWritten; DWORD iBytesRead; HANDLE SerialInit(char *ComPortName, int BaudRate) { HANDLE hComm; hComm = CreateFile(ComPortName, GENERIC_READ | GENERIC_WRITE, 0, // exclusive access NULL, // no security OPEN_EXISTING, 0, // no overlapped I/O NULL); // null template bPortReady = SetupComm(hComm, 1, 128); // set buffer sizes bPortReady = GetCommState(hComm, &dcb); dcb.BaudRate = BaudRate; dcb.ByteSize = 8; dcb.Parity = NOPARITY; //dcb.Parity = EVENPARITY; dcb.StopBits = ONESTOPBIT; dcb.fAbortOnError = TRUE; // set XON/XOFF dcb.fOutX = FALSE; // XON/XOFF off for transmit dcb.fInX = FALSE; // XON/XOFF off for receive // set RTSCTS dcb.fOutxCtsFlow = FALSE; // turn on CTS flow control dcb.fRtsControl = RTS_CONTROL_HANDSHAKE; // // set DSRDTR dcb.fOutxDsrFlow = FALSE; // turn on DSR flow control dcb.fDtrControl = DTR_CONTROL_ENABLE; // dcb.fDtrControl = DTR_CONTROL_DISABLE; // dcb.fDtrControl = DTR_CONTROL_HANDSHAKE; // bPortReady = SetCommState(hComm, &dcb); // Communication timeouts are optional bPortReady = GetCommTimeouts (hComm, &CommTimeouts); CommTimeouts.ReadIntervalTimeout = 5; CommTimeouts.ReadTotalTimeoutConstant = 5; CommTimeouts.ReadTotalTimeoutMultiplier = 1; CommTimeouts.WriteTotalTimeoutConstant = 5; CommTimeouts.WriteTotalTimeoutMultiplier = 1; bPortReady = SetCommTimeouts (hComm, &CommTimeouts); return hComm; } char SerialGetc(HANDLE *hComm) { char rxchar; BOOL bReadRC; static DWORD iBytesRead; bReadRC = ReadFile(*hComm, &rxchar, 1, &iBytesRead, NULL); return rxchar; } void SerialPutc(HANDLE *hComm, char txchar) { BOOL bWriteRC; static DWORD iBytesWritten; bWriteRC = WriteFile(*hComm, &txchar, 1, &iBytesWritten,NULL); return; } int main() { HANDLE my=SerialInit("COM1",9600); char letter; printf("test\n"); HANDLE *ptr; *ptr=my; for( ; ; ) { SerialPutc(ptr,'A'); printf(" %c ",SerialGetc(ptr)); getch(); } return 0; }
