sjb741
Junior Member level 2
Suppose there are two air-core coils. Same count of turns (say 1 turn) but different geometries. Primary P, secondary S.
For example, maybe P is circular with diameter 0.1m and S has diameter 0.3m.
(1) By measuring Lp with coil S open (or distant), then measuring again with coil S in "the designed position" (and shorted), is it valid to calculate coupling k as follows? My concern is the coils have different geometries.
k = sqrt(1 - Lx/Lp)
where
Lx is primary inductance with S closed
Lp is primary inductance with S open
[Question: Does the validity of the calculated k value require the coils are parallel?]
Reference is here
(2) If instead I simply have the data I(P) and I(S): With only that data, can I calculate "k"?
k = sqrt(1 - Lx/Lp)
where
Reference is here
