I'm using easypic5 to program, the problem is that the programmer detect other device, it can't detect the IC I'm using the PIC16F628A. Could you help me solve this, because at first it working right but now it encounter this problem. Thanks
Check whether the 5 ICSP Programming pins are correct with accordance to the PIC or if you are using ZIF socket, then your PIC location is s correct? Most people install the PIC with the wrong ZIF location
