Detect low voltage and power outage detector
romel_emperado
Advanced Member level 2
philippines
Hi guys Im planning to make an automatic failover system.
our power line is 220VAC and I want to consider 8% of that is already low voltage and it should turn on the backup power..
power cut off is easy to detect but Im asking idea on how to properly detect the low voltage....
anyone?
I will use PIC MCU for this experiment..
Thanks so much
simply use ADC sensing topology . like this ,,,,,
  Main Program
void main()
   disable_interrupts(GLOBAL);
  // Initilize RAM Variables
  ..// Do something
   enable_interrupts(INT_TIMER1);
   enable_interrupts(GLOBAL);
   while (1)
     // Do something
if (volt <= 202)
      return(low_VOLTAGE);
   } // Loop Forever
} // End Main
yes.. i should ask in my previous post if it's not dangerous if I monitor directly to the power line?
I'ts all about some simple circuit before I sense the voltage to my ADC.
yes it's all about ADC topology but 220V is big for my adc..
can I use step down transformer for this to detect 8% low voltage? A 12V secondary output transformer
---------- Post added at 18:34 ---------- Previous post was at 18:33 ----------
Im not sure if I can detect it by using a transformer
have u any proper sch for it .
yes u can use step down transformer for this to detect 8% low voltage , or step down 220 v ac supply using diver network .
what mcu u want to use ?
OK ...
I don't have schematic I just imagine what will I do in the future
I got that.. thanks so much.
will let you know the update..
