delay header file
hi
i am interfacing the lcd with pic16f877a and i got the source code . in tat code i got the header file delay.h .i cant understand about this file plz help me and i attached the file ...
* Delay functions for HI-TECH C on the PIC
* Functions available:
* DelayUs(x) Delay specified number of microseconds
* DelayMs(x) Delay specified number of milliseconds
* Note that there are range limits: x must not exceed 255 - for xtal
* frequencies > 12MHz the range for DelayUs is even smaller.
* To use DelayUs it is only necessary to include this file; to use
* DelayMs you must include delay.c in your project.
/* Set the crystal frequency in the CPP predefined symbols list in
HPDPIC, or on the PICC commmand line, e.g.
picc -DXTAL_FREQ=4MHZ
or
picc -DXTAL_FREQ=100KHZ
Note that this is the crystal frequency, the CPU clock is
divided by 4.
* MAKE SURE this code is compiled with full optimization!!!
#ifndef DELAY_ROUTINE //-- Check if already loaded!!!
#define DELAY_ROUTINE //-- MAKE SURE CANNOT RELOAD
#ifndef XTAL_FREQ
#error NO XTAL_FREQ DEFINED - Is Required for DelayUs!
#define XTAL_FREQ 8MHZ /* Crystal frequency in MHz */
#endif
#define MHZ *1000 /* number of kHz in a MHz */
#define KHZ *1 /* number of kHz in a kHz */
#if XTAL_FREQ >= 12MHZ
#if XTAL_FREQ >= 20MHZ
void DelayUs(unsigned char x)
unsigned char count,_dcnt;
for(count=0;count<x;count++)
_dcnt= ((XTAL_FREQ)/(8MHZ)); //-- 1us worth of delay
while(--_dcnt !=0);
#else
#define DelayUs(x) { unsigned char _dcnt; \
_dcnt = (x)*((XTAL_FREQ)/(12MHZ)); \
while(--_dcnt != 0) \
continue; }
#endif
#else
_dcnt = (x)/(12MHZ/(XTAL_FREQ))|1; \
continue; }
#endif
extern void DelayMs(unsigned char);
#endif
thank you.......................
