kak111
3-phase ac motor controller system
The MC3PHAC is a single-chip intelligent controller designed specifically to meet the requirements
for low-cost, variable-speed, 3-phase ac motor control systems.
One of the unique aspects of this device is that although it is adaptive and configurable based
on its environment,
it does not require any software development,
which often translates into extra tools, expertise, and longer design cycles.
This makes the MC3PHAC a perfect fit for applications requiring ac motor control but with limited
software resources available, a tight schedule, or both.
https://cache.freescale.com/files/microcontrollers/doc/app_note/AN2988.pdf?aspll=1
FreeMASTER software is one of the off-chip drivers, which supports communication
between the target microcontroller and PC.
This tool allows the programmer to remotely control an application using a userfriendly
graphical environment that is running on a PC.
It also provides the ability to view some real-time application variables in both text and
graphic form.
FreeMASTER — embedded side drivers (HC08, HC(S)12,
MPC5xx, DSP56F800, MC56F8300, MC56F8100 family)
https://cache.freescale.com/files/microcontrollers/doc/fact_sheet/FREEMASTERFS.pdf?fsrch=1&sr=1
on its environment,
graphic form.
