Designing of Photodiode Layout in 0.18u CMOS process
ammadupm
Newbie level 5
Newbie level 5
I would like to draw the layout of photo-diode in Hynix 0.18u CMOS process.
Plz help.....
erikl
Super Moderator
Staff member
Advanced Member level 7
Germany
Use a p+ in N-well structure: photodiode_cross_section.png Also check this thread!
dick_freebird
USA
Behind the basics there are some nuances that relate to
things like suppressing / minimizing RTS (RTN) noise, field
control and so on. Applications which need very low dark
current and cryo operation care a lot about this; a receiver
for short haul fiber optics, less so.
Give some thought to your application care-abouts, and
the literature may help you with the finer points of device
construction.
ammadupm
Newbie level 5
Newbie level 5
Can you check this Schismatic and layout of the Photo-diode.............Is this correct?
erikl
Super Moderator
Staff member
Germany
You just need one photodiode in layout: the other one (in schematic) is a parasitic diode between n-well and substrate. See this image:
The area of the parasitic diode (the n-well area) is bigger than the pd (the p+) area.
The quadratic structure outside around the p+ diffusion area is the border between two recognition areas, s. this post.
ammadupm
Newbie level 5
Newbie level 5
Plz check this now..........
I draw the layout as explained by erikl, but may be few errors are still in LVS check.......
erikl
Super Moderator
Staff member
Germany
Seems ok. If (and which) recognition layers are necessary for the LVS check to match, depends on your PDK's extract rules.
You wouldn't need the extra n-well contact, the n+ guard ring contacts are enough. So you could save some area: the n-well diffusion area can be with min. spacing outside the n+ guard ring, and the p+ substrate guard ring may have min. spacing to the n-well.
