[SOLVED] Designing Low Noise Amplifier
Nornabila Md Nor
Newbie level 3
Newbie level 3
Hello...i want asking about designing LNA.How can we combine matching circuit with voltage divider biasing?Kindly please answer my question because i really do not know how to combine it..Thank you
This LNA design for frequency 4GHZ by using transistor ATF54143 Avago Technologies.Is it relevant use voltage divider as biasing for 4GHz??
Dear Norbila Md Nor. You can use these pdf files. I wish this helps!
  • AV02-0488EN+DS+ATF-54143+08Jun2012%2C0 (7).pdf
  • AV01-0621EN%2C0.pdf
Thank you for help.This low noise amplifier at 4GHz successfully design and testing.Finally,my final year project achieve the target.
