Designing LNA with FHX13LG in AWR
pourrahim.mahdi
Newbie level 3
Newbie level 3
Hi everyone
I want to design an LNA with FHX13LG transistor. We know that for this transistor there is only s2p file. My question is that how should I make the dc biasing circuit using the s2p file. I tried it on my own but when I'm changing the values for Resistors , the current (I) changes , but the Vds stays the same as the dc voltage source.(if I chose the dc voltage source 2 volts, Vds changes to 2 volts too)
Yes, of course the currents and voltages stay the same if you use linear measured data (s2p) where the measurement was done at one fixed bias point.
You can include the bias layout in the linear MWO simulation, but the transistor will not "see" the supply and voltage changes. You need to think about the yourself without help from the simulator. It's not complicated, use the information from the transistor data sheet.
In additional to this, you don't have to have nonlinear model for this transistor because if the transistor works under mentioned operating and bias condition,its NF will hopefully be as measured and mentioned in its datasheet so therefore you don't have to simulate in nonlinear region.Just match it in according to NFmin impedance and try it on a proper board with playing around bias voltages/currents.
So, s-parameters ( NF information ) are good enough to obtain a performance in term of Noise.The others can be tweaked on the board.
Thanks BigBoss. I think you are right. I did as you said and looks like the results for NF are right.
