Designing Gps devices
Mahammad
Member level 3
Hi , i want to build a simple gps device .no matter what may be its area .plz help me:)
yassin.kraouch
Advanced Member level 2
what do you mean by GPS device ? a simple GPS receiver ?? please explain more
vinodstanur
Advanced Member level 3
Kerala (INDIA)
What exactly you mean? You want to make a GPS receiver?!!
OR
A GPS module based project?
---------- Post added at 23:16 ---------- Previous post was at 22:58 ----------
If I am right, a GPS device is something much much complicated and it is not so easy to make it.
But it is easy to use a GPS module since what we need to do is just to read the GPS data from the GPS module using a microcontroller via a serial interface.
---------- Post added at 23:18 ---------- Previous post was at 23:16 ----------
just read this post and see how difficult it is:
Build a GPS receiver?
bigdogguru
Administrator
Southwest, USA
Here are a few examples of interesting GPS projects:
Ice Tube Clock
GPS to SD-Card Data Logger
GPS-based universal clock generator
GPS-logger
Interfacing an AVR controller to a GPS Mobile Phone
They should give you some ideas. I've seen GPS Modules for as little as $30 here, but depending on the options they can quickly increase in price.
BigDog
---------- Post added at 23:50 ---------- Previous post was at 23:47 ----------
The connection between MCU and GPS are usually asynchronous serial or RS-232.
For most people the hardest part of the project is designing a parser for the GPS NMEA sentences.
There are however several open source NMEA parsers available in C source code.
Mahammad
Member level 3
I want to design a gps receives that shows my position .i need not be very accurate .my position may differ by around 20 miter
bigdogguru
Administrator
Southwest, USA
Do you need portability, otherwise a GPS with a RS-232 will provide a location using a number of free PC GUI applications.
Otherwise a simple MCU with LCD readout and battery will provide the information you want in a portable configuration.
BigDog
