jmarkwolf
Junior Member level 3
I am designing a data acquisition system for a very specific application. My signal sources will have a 2.5V DC offset and I was planning to use a mono-polar A to D.
It may become desirable to perform FFT's on the captured data, which requires no DC offset.
Is it advisable to null the signal sources to zero volts in hardware and make appropriate changes to my power supply and A to D, or is it just as effective to do it in software and keep the hardware simpler?
Also, how can you test the end-to-end phase error introduced by the hardware?
All suggestions gratefully received.
