design steps and basics of microstrip PATCH antenna ????
gbaerf
Full Member level 2
belongs to whole word
antenna design steps
Please tell me if possible the complete design steps and issues of microstrip PATCH antenna design and basics of the patch antenna
please suggest me if any relavant link is there...
and why do we go for PATCH antenna is it depends upon the application or any other
specific advantages are there.
what are the advantage of PATCH antennas ????
any explanation on the feed methods of the antennas...
Thanks and regards
Syukri
Full Member level 5
Malaysia
patch antenna + design steps
1. Find the freq. of your application. Example for devices of bluetooh the frequancy of operating is 2.45 GHz
2. Find the type of material(PCB) that you wanted to use like Duriod or other. Go to RT Duriod web site and get all the parameter u need in calculation like relative permittivity εr and relative permiebilty µr.
3. Choose a model(a group of mathematical Equation) to build calculate your Width (W) and Length (L). You will use εr and µr in order to get W and legth trough ξeff and etc.
Remember to calculate width first then length. Transmission line model is the easiest.
Your W should be ≈L/2 to get a good design
Book on MIcrostrip Antenna will help: recomemded one by Bhal & Bhartia.
Good luck:D
I've done this before using Matlab
