design single-ended opamp
electim2004
please guide me to design opamp:
single-ended opamp
Adc>80db
Fu>=160Mhz
PM>=70deg
output voltage swing>=1.8vp-p
Vdd=2.5V
Pdiss<=5mw
L=.25U
WHAT IS PROJECT PLAN?
w1,...=?
Cc=?
please guide me.
there is a design procedure from P. Allen's book, try to find and follow it. It's not difficult
use gain boosting structre
i am doubtful whether simple two stage class-A opamp can provide 160MHz UGB.please clear me if i am wrong.i thing we have to choose the folded cascode opamp for 160MHz ugb.
I think it may be the single stage fold-cascode amplifer with the gain-boost technique.
For the .25 mico technology, the bandwidth of two stage amplifier may be attained if offset is not dominant parameter with all minimum length design.
Use an OTA or so-called 2-stage CMOS Op-amp. The internal feedback is the key to push the linear bandwidth to 160 MHz, by means of gain boost in the gain stage.
you can refer to Allen's book
i think 160MHz is accessable in 0.25 tech
hehe
i have doubt about D.C gain of 80 dB, other things are achievable.u can use folded cascode opamp for ur design. see allen-holberg.
thanks.
