design of two stage opamp by gm/Id method
analogfreak
Newbie level 1
Newbie level 1
Two stage Opamp with miller compensation was designed with gm/id =13 and circuit is functioning properly for open loop. However, when this opamp is simulated as a unity gain buffer a few transistors start operating in linear region. What might be the cause for this behavior?
Please help
When the value of vds<vgs-vth, the transistor will operates in linear region.
Please help
You probably changed the DC feedback from the open loop to closed loop circuit.
LaTeX Commands Quick-Menu:
