Design of transistor test fixture
jayce3390
Full Member level 6
I am designing my own Test Fixture to measure a packaged transistor, the TF is composed of 2 launches (with biasing path) and a line to make the TRL calibration.
The TF center frequency is 2185MHz and it's 50 ohms reference impedance. I would like to be able to perform measurement from 0.5GHZ to 8GHz, but It seems that the launch has S21 resonnant frequency about 4.5 GHz, it is a problem.
This is due to bias circuit. i don't know how to get a flat S21 full bandwidth.
My project is available here.
I don't have ADS, so I cannot open the project, but from the image, it seems that the biasing path is acting like a stub. Try to remove it and simulate.
You need to design a wideband biasing or use an external bias tee.
I hope it can help.
Mazz
    jayce3390
Mazz,
Tha biasing path is composed of a lambda/4 ustrip line combined with a shunt capacitor under Taconic RF35 substrate.
You say me that I should use an inductor like that ?
but with this kind of inductor, the limit of current is about 1A (CW), it is too low for my application :cry:
With microstrip line it's more easy to reach high level of current (3 or 4 A in my case).
I havent designed any large bandwidth tee bias, but...
Those inductors are for very large bandwidth (>10 GHz, if I well remember.)
Some time ago I opened up and repaired a bias tee: they used a circuit made by different sized inductors (there was also a transformer) to prevent self resonant freq (see https://www.qsl.net/n9zia/wireless/pics/bias_tee.png to have an idea).
Or you can try using large bandwith stubs + some discrete.
I hope it can help.
Mazz
