design of rectangular monopole antenna for uwb range using hfss
agopichand88
Junior Member level 1
hello everyone I'm doing a project on rectangular monopole antennas with notch frequency function and i have created the geometry can
someone help me on how to assign boundary conditions and setting up the solution parameters and getting the solution
My refernce papaer:printed UWB Antenna with Coupled Slotted Element for Notch-Frequency Function View attachment 351924.pdf
My simulated geometry without H-shaped Notch:View attachment Ansoft.zip
1st tell me do you know how to start the simulation after designing the antenna.
are you asking about the procedure to do the simulation?
no i dnt knw how to consider boundary and excitation conditions and how to setup the solution parameters
that would be really greatfull if u can do it
ok i will do it for you but is this design that you attached here, is made by you?
yes but i have to do the h - slot in it
but you already have assigned the bounday, only the small area of ground plane is left where you have to make the H slot and you have assigned the boundaries correct
yes i will do the h slot too but the problem is when i'm trying validate all then it is showing some kind of error which i dnt knw and also do u knw how to caluclete return loss and how to get the surface current animation shown in the article
yes i do know how to get the plot of return loss
nope as i said earlier when i'm trying to simulate it is showing error in boundaries i dont know how to solve it
