design of half wave dipole antenna
ashokone
Member level 3
banglore
hi
is it possible to design dipole antenna for 50ghz and above..which tool support this..
is it freely avaliable other than matlab.
if i am using matlab for the design of antenna,i want to know the dimension in pdetool.. how to check these dimension
vfone
Advanced Member level 5
No, is not possible.
ashokone
Member level 3
banglore
hi vfone
what you are saying is 50Ghz design is not at all possible with any tool.
if so which tool i can use for this? help
Chinaski
Spain
You can design a half length dipole at whatever freq you want and you don't need any sophisticated tool (freely NEC versions are enough, even paper and pencil). I think vfone says that, even if you can built it (two arms of 1.5 mm length) it will not work as an antenna. Losses will ruin its radiation efficiency. It's an useless work.
In electromagnetics (well, in engineering), there is always a long path between simulation and real life
Don't believe sales people "From your PC to the first time working proto" design doesn't exist.
That's life
kekosat300
Member level 4
The half-wave dipole is always a half-wave dipole, no matter the frequency since the real length is normalized to the wavelength. So, the radiation properties of a dipole 3 mm long at 50 GHz will be the same as the radiation properties of a dipole 3 m long at 50 MHz. Both dipoles are half-wave dipoles at each frequency. However, conductor losses are not scalable with frequency, so a greater loss resistance will appear at 50 GHz, which affects the radiation resistance of the dipole.
kekosat300
Member level 4
It is enough using a wire antenna code, like NEC-based (MiniNEC, EzNEC) or **broken link removed**.
