Design Of ESD For Transmitter Driver
Analog_Domain
Newbie level 6
Hi
Im doing LVDS driver circuit for transmitter, now im asked to implement any type of ESD cirucuits at the end of driver. Any of you can explain how can it be designed. Any test bench for verifying ?.
Thanks
dick_freebird
Advanced Member level 5
USA
If you don't have any unusual requirements like cold-sparing
(i.e. output does not leak back when VDD=0) then the usual
CMOS digital ESD schemes could be applied. If you need
"power off high impedance" on the outputs then probably
need to use a GGNMOS clamp per output (possibly with a
back diode).
Verifying ESD performance can be a problem because the
device operates in two modes which interest modeling
engineers not at all; "off" and "snapback". I've run into
nothing but apathy there and always had to fit my own
models (I tend to just overlay a properly parameterized
diode model, kill the forward and fit the reverse params).
But you need TLP data to get at the post-snapback
resistance.
Analog_Domain
Newbie level 6
Thanks for the ideas, Any additional info for verifying the ESD? Are we need to implement for both modes seperate test bench and check?
