Note: This feature currently requires accessing the site using the built-in Safari browser.
I want to design a receiver that receives a morse code signal in the 195Khz to 400kHz band. Is it possible using components easily available in the market?
There's the question whether (a) you will need only to detect the simple presence of the carrier as is normally done with morse, or (b) whether you will need to demodulate the occasional signal riding on a continual carrier.
Frequency range = 195/400 KHZ, therefore inductance swing = 4 :1. With a slug I would have thought 1.2 :1 more likely?
Frank
