freqzt
Hi All.
My current work is about uwb antenna. My antenna using microstrip and I want to design fractal antenna. I simulate my antenna using Micro-Stripes 7. When I design the 3d shape using build there is no problem. But when I calculate it there is a warning "the equivalent surface used to monitor near field overlaps a port". I don't know how to eliminate this warning. I use CPW to feed the antenna. Can anybody help me? Is this warning will influence the accuracy of my fractal antenna? If yes, what should I do? Thanks guys.
