hans_r
Newbie level 5
i'm designing a comparator for a 12-bit AD-converter. I'm having some problems concerning the driving of the digital blocks after the comparator, and have these thoughts about it:
The comparator should always output a 0/1, otherwise the digital block will go in an undetermined state.
Considering the comparator as an amplifier:
Since the difference voltage at the input of the comparator can be randomly small, there will always be cases when the output of the comparator is not high/low enough to be considered as a logic 1/0, and therefore I can not drive the next stage!
Adding an inverter does not help, since the inverter will also go in undetermined state.
The idea is that the comparator should latch to a digital value, right? Is a schmitt trigger the solution?
Does anyone have any idea how to solve this? I guess it is a basic analog-digital interfacing problem!
Kind regards!
Hans
Kind regards!
Hans
