Design Kit error or cadence error
whitewiz
Member level 3
LA
ppar is undefined or is used recursively
I installed the TSMC 0.35um CM Process design kit in my unix system.
When I run the simulation in the analog envirnment in Cadence Virtuoso, I always got the error message so I can not use that at all. I am not sure this error is originally design kit error or cadence error/
Do you know what this error message means?
Please help me the comment for me. Thanks
Error found by spectre in `pip', during circuit read-in.
"/auto/home/project/tsmc35mm/../skill/../models/mm0355v.scs" 2448:
Function `v' is undefined or is used recursively.
spectre terminated prematurely due to fatal error.
tsmc35mm
I get the same kind of error!
Function pPAR in (XYZ) instance is undfnd or used recursively!
However, it works after some time ...
i use IC.5.1.41
Added after 4 minutes:
Error found by spectre in `inv1', during circuit read-in.
"input.scs" 15: Function `pPar' is undefined or is used recursively.
"input.scs" 16: Function `pPar' is undefined or is used recursively.
"input.scs" 23: Function `pPar' is undefined or is used recursively.
I never used recursively at all. I can not simulate at all.
How do you fix the problem ?
maybe your model file is not in unix format. you can try the following comands. dos2unix *.scs *.scs
it will start working if u copy d design and name it differently...... i just used HIT & TRIAL nd d thing wrked fr me ... dn knw wts cache behind this bt..... hope it helps[:)]
you pdk file path is not correct.
use ADE setting to add them.
