design double switch forward
rajabi_u
Newbie level 5
double two transistor forward
hi all
can you help me?
i want design double switch forward that input voltage was 230(+10%;-15%)v:
output voltag was 12±1% v;output current was 20A ;
this switch should be controlled by IC SG3842;
if you knew which book is good for this desine ;that is very good for me.
thanks a lot
rajabi
sg3842+application note
Start with a google search on "two transistor forward converter design"
and you will find quite a bit.
https://www.google.com/search?hl=en&lr=&q=two+transistor+forward+converter+design&btnG=Search
Take a look at this application note for example
www.fairchildsemi.com/an/AN/AN-7004.pdf
Study the section on the two-transistor forward converter and see what
devices are being used and then you might want to browse more application
notes and I am quite certain you will find enough information to put
together a design.
Best regards,
\[v_c\]
double switch forward converter
Hello v_c;
Thank you very much from your answer,
Can you give more becase for design transformer and control by IC;i have problem.
Thanks a lot of.
Regards
