Design Compiler warning OPT-1206
jayTudu
Member level 1
opt-1206
Hi designerAll,
Can any one suggest me how to avoid the warning OPT-1206 in design compiler.
The OPT-1206 defination is: " The register Ro is constant and will be removed ".
This warns that some of the flipflop from my design are getting removed as a result
of optimization, but I donot want any of the filpflop to be removed from my design.
Is ther any command which can serve this purpose ?
Thanks n Regards,
JAY...
dcreddy1980
Full Member level 5
Munich, Germany
the register is a constant design compiler
To preserve Flip flop from being removed by DC, apply the below command :
set hdlin_preserve_sequential true
aravind
Advanced Member level 1
india
various warnings design compiler
I have another question, how to avoid sequential merging in DC. Is DC doing sequential merge across hieriarchy?
Thanks
Aravind
jayTudu
Member level 1
design compiler warnings
Thanks dcreddy... I will try this command
Hi Aravind can you just explain what is sequential merging, I may try to search for an answer for you.
raju3295
Full Member level 4
design compiler boundary optimization
i dont think so,, any tool will merge the hierarchies and do the optimizations across the hierarchies,, untill u ask to do so,,, so sequential merge across hieriarchy may not occur
D Saurabh
Junior Member level 1
Singapore
design compiler
The switch -boundary_optimization (compile -boundary_optimization) will result in optimization across hierarchies. Make sure u don't include it in case u want to prevent it.
eeeraghu
Full Member level 4
design compiler -edges
after boundary optimization use set register merging as false for that particular register inorder not to remove or merge that particular register for particular reasons.
