design compile can't work. what's the matter?
tavidu
Member level 1
dc shell can't load the library.
when I enter dc_shell-t, such message occurs:
DDB-44(error) Can't read unprotected library 'slow'
Anyone could tell the reason? thanks
Check what version of library compiler is used to comple ur library to .db format.
If it is older than ur dc_shell version you will get such an ERROR!
If you have .lib file for ur library then first using lc_shell get it complie to .db
and use it. This will solve ur problem.
Please remember while posting such questions you must write what version of
tools ur using and on what platform.
could it be also because you do not have the read access to the library file (.db format).
check your".synopsys_dc.setup".
