design a reconfigurable antenna
nagaraj174
Newbie level 2
hi sir ,
This is B.Nandanaik, i am doing some mini project work on RECONFIGURABLE antenna using IE3D simulator , but i dont know that much about IE3D. so please and if possible send me the layout as well as simulation results. I am attching the pdf file here.
thanks in advance.
Hi, nagaraj174:
I think some people asked about the same antenna and I did some file for him. However, I forgot where I put them and I could not upload it to you.
You can build them on your own. The polygons should be simple to build. The most important things are the switches. Please build them as some h-localized ports. Then, after simulation, you can use MODUA to put OPEN or SHORT to emulate the off and on states.
best regards,
