Design a comparator with hysterisis
lowell
Newbie level 5
Sir:
May I ask for a design of a comparator with hysterisis using the op-amp MAX4309ESA???
This will be used as part of my undergraduate thesis.
Thank you...
Lowell
hysterisis comparator
Hi.
Here's one design based on the opamp you mentioned.
A transistor inverter at the opamp output helps to give digital logic levels(typical of comparator).
Also, if you want to experiment with different hysteresis at high side and low side use the two diodes(shown in fig.)
Hope this helps, and welcome comments,suggestions!
Giri[/img]
comparator hysterisis
hello,
isn't comparator with hysterisis = schmitt trigger?
greets
comparators w/ hysterisis
not the same,but similiar
comparators with hysterisis
A schmitt trigger would have implemented a comparator with a hysterisis,right?
What's the difference?
Giri
design of comparator
http://pdfserv.maxim-ic.com/en/an/AN3616.pdf#search='maxim%20comparator%20with%20hysteresis'
