nitinigam
Newbie level 3
I want to design a barrel polishing machine in which a cavity is to be finished internally. In this method cavity will be mounted on a structure which will be rotated by some RPM and this cavity will also rotated by some RPM wrt to own axis. the cavity is fillled with some polishing media of known weight. i want do do analysis an ansys to ensure that the cavity will not deform or yield when it will be rotated in centrifugal barrel polishing machine
