K
krivan
Hi folks,
I have an application where I have to have an analog 4:1 multiplexer and an analog 1:4 demultiplexer. Basically I have to design some switching logic to connect 4 transistors to two amplifiers.
So I designed the multiplexer with a conventional transfer-gate logic, it works fine.
However, when I want to use this circuit in reverse mode [see pic1] somehow I can't select one specific output. The input voltage appears on the right output but lower voltages appear on the other outputs as well. These voltages are lower than the input one.
I tried also to have 4 transfer gates and switch on/off them using a 2-to-4 decoder but the result is the same, although the control voltages of the transfer-gates are provided fine[from the decoder].
So I don't understand. There is one 4:1 MUX which works OK. I wanna use a slightly modified copy of it [rotated the transfer-gate blocks because the input/output ports] in reverse direction and it does not work however I use exactly the same transfer-gate blocks.
Does anyone have idea how to design then a proper analog demultiplexer? 1:4
Thx,
Krivan
Thx,
Krivan
