Dell 1545 laptop dim display
sivakumarkollam
Junior Member level 1
My dell 1545 laptop is dim display (15.6 l c d). Inverter board voltage is okay,i change new l c d and inverter board..did not get bright in l c d..can you help me...
Yes i check first it after new 15.6 lcd and inverter changed
CCFL and inverter works then. Did you open LCD panel completely and see that CCFL have light on full lenght?
first time ccfl is not work so change inverter..not get light. after i will change lcd 15.6.. not get result
Does LCD screen showup any picture? Did you try to light with some handlamp? Or best is to open panel and from back side to use handlamp.
If you dont have anything on LCD screen then look motherboard VGA section.
ya that's on mother board VGA section...WHAT CAN I DO...HOW TO FIND OUT THIS IC...
How to find out this chip... Chip number or ather idea
