Delaying signal in Actel FPGA
guybrush
Junior Member level 3
DELAY IN FPGA (SDF file)
Hi all.
I have to implement a 50 ns (nominal) pulse, 200 KHz using an FPGA that has a 2 MHz clock. I'm using an ACTEL fpga and the envirommental constraint are -25/+90°C.
Since it is imposible to produce a 50 ns pulse with a synchronous logic clocked @ 2MHz, I decide to use an AND gate in which one of the two input is a 200 KHz square wave and the second input is the same signal delayed. The simulation gives a 50 ns pulse in standard conditions.
The duration of the pulse is dependent on:
1) Voltage
2) Temperature
3) Process
Simulations show that the duration will be between 30 and 100, meeting my constraints.
You think this could be a good solution? Any suggestion?
Where can i find the description of the SDF file format ?
Thank you a lot.
