Delay Using Timer1 pic 16f628a + CCS compiler PCM 4.068
raflab
Newbie level 1
I'm trying to create a delay with N minutes using timer 1 .. I found the following code
#include <16F628A.h>
#fuses INTRC_IO, NOWDT, NOPROTECT, BROWNOUT, PUT, NOLVP
#use delay(clock=4000000)
void main()
int16 delay = 0;
SET_TIMER1(delay);
SETUP_TIMER_1(T1_INTERNAL | T1_DIV_BY_8);
while(TRUE)
   if(GET_TIMER1() <32768)
      OUTPUT_LOW(PIN_A1);
   if(GET_TIMER1() >32768)
      OUTPUT_HIGH(PIN_A1);
So if is it possible I want to replace the 0.5 sec by 2 minutes ( for example )
( I said N minutes because that's related to the user that he will be able to send it through VB interface using Serial port communication )
I won't use the delay_ms because it will be imprecise
I really need some help !! :-|
Thanks
For quartz 4MHz vs TMR1 maximum possible delay is 524,28ms
But you can make variable counter, for example i:
   while(1) {
     //procedure setting timer1 (tmr1h tmr1l = 62500)
     if(TMR1IF) { i++; TMR1IF = 0;}    // I'm not sure for this in CCS
     if (i == N) {                                // where N - time in seconds
                     PIN_A1 = !PIN_A1;
                     i = 0;
And best choice for this task - using interrupt
    V
          i++; TMR1IF = 0;
                   if (i == N) {                                // where N - time as a multiple of 524,288 ms
                     PIN_A1 = !PIN_A1;
                     i = 0;
Moving the above segment to the ISR lets you multitask - do something else while waiting for the timer to overflow. For that, you also need to set the interrupts, so
   INTCON = 0xC0; //GIE = 1, PEIE = 1
   PIE1 = 1; //TMR1IE = 1
This enables the interrupt associated.
Hope this helps.
Tahmid.
