Hello, I need to make a delay cell giving about 100 us delay using mosfets. The cell needs to have a trigger input. Can someone give suggestions ? Thanks and regards.
If you´re working w/ ASIC design that amount of time seems very large and space needed will be very expensive to waste w/ that function.
Maybe is better you implement something based on counter solution.
Timered solutions based on silicon dopping characteristics are highly affected by temperature and thus result is imprecise.
Maybe could be not the better choice.
Think about a syncronous based solution.
