alehan99
Newbie
HI
I wonder to know how Deep Nwell could improve the total noise isolation of analog NMOS transistor in digital noisy environment. I know that DNW should isolate the NMOS bulk from bulk noise ( in addition to guard ring) but the Analog and Digital blocks shares the same supplies, means that both analog and digital blocks should see the same supply noise without any filter separation between VDD of digital and VDDA of analog, i. e. VDDA = VDD are the same by value and by noise.
I think that DNW in this case filters the bulk noise but harms the performance cause an additional VDD noise is coupled to NMOS analog transistors through DNW connected to VDD, and this noise is higher than filtered bulk noise.
p.s. analog circuit operates in low frequencies ( up to 1M) and rounded from all sides by digital blocks.
Thanks
Thanks
