mush
Junior Member level 2
- Joined
- Mar 6, 2014
- Messages
- 20
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 163
Dear all,
I am currently designing a simple FMC board. The board receives and sends differential signals (max 320MHz) through mini sas connectors and sends them to a xilinx board through samtec ASP-134488-01 with the help of SN65LVDS122 translators. I want to ask you from your experience, which is the best "topology" for the layers? Do I have to use Top-GND-Signal-Signal-PWR-Bottom or it is better the GND-Signal-GND-PWR-Signal-GND (in this case probably the signal layers are not enough). Is it better to isolate the differential signals from the "outer world"? Is it better to use a ground plane on the side of the ASP-134488-01 because of the many ground pins? Generally, is there any rule for the decision of the planes?
Thank you,
Mush
Thank you,
Mush
