Decaying sounds synthesis with PWM
amaze1
Junior Member level 2
Do anyone knows if is it possible synthetizing (no pre-recorded sounds play) with reasonable precision (e.g. acceptable audio quality) decaying sounds like bells, carillons, gongs etc with mcu's PWM only ?
I mean no external programmable amplifiers or so, at least just a passive filter.
Some code example or algorithm welcome.
Thanks in advance
Well, the only thing i can think of is doing what the old analog synthesizers used to do: an envelope with a fast attack.
Just use a sine table and an array containing the envelope values. At every sample instance multiply corresponding values of each and use that as the pulse width.
However this sound will be very far from that of real bells. For that you would require frequency modulation.
Reactions: amaze1
    amaze1
This isn't what I was looking for.
I hoped it is possible mimic the decaying sounds spectrum with PWM's square wave and some kind of frequency or duty cycle modulation.
Thanks so much anyway for your effort
PS: By The Way: how is the spectrum of such decaying sounds ?
Sure. :) But I don't think you can modulate the frequency of the PWM wave on the fly in most, if not all, MCUs...don't they just have a prescaler to derive the wave frequency?
And we are doing duty cycle modulation to get an analog wave from a PWM. In the analog synths with PWM, what they had were square waves with specific frequencies mapped to different keys, whose duty cycle could be changed or modulated to get desired effects. In the MCU case we have to modulate the PWM signal to just get the basic waveform.
The spectrum of real bells must be full of harmonics at the attack stage, which would gradually die down to signal of a few harmonics, till it decays away...
