[SOLVED] Debugging kernel, How ?
Raady Here
Full Member level 5
Full Member level 5
India
If I was given a crashed or hanged up kernel , I want to analyse what had happened ?
How to start debugging the kernel ? Is there any link related so that I can understand better or any one can send steps and procedure to debug a kernel.
Regards,
Raady.
you should get a memory dump...................the rest is art and skill and hard work
As first think, you should understand what crash your kernel. Is it a vanilla one? Are you writing a module?
Before tol debug a kernel isfundemental to know what is the issue.
Try dmesg and or syslog.
To debug kernel is very difficults and is impossible to be described as a linear sequence of steps.
Lollo
Lollo
My teacher had given me a crashed kernel zimage and asked me to debug.
I want to know where to start it ?
I have seen some in searching it could be done using backtrace / ltrace/strace. But I couldn't find any documentation regarding that , using how and debug.
I want to know any links which has steps to follow.
Regards,
Raady.
What do you mean with 'crashed kernel zimage'... a core dump?
If you have yes ,you have a snapshot of the crash situation and you can debug it by gdb, too. I hope for you that the kernel has bee compiled with debug options enabled :)
Lollo
what are the step to follow to debug using gdb ?
