shubhangibhosale
Hi all!
Attached is a picture of meander lines that were fabricated for measurements. however there is a difference between the measurements and simulated results for s parameters.
SMA connectors(top mount) were used, and only two of the pins of the connectors were actually soldered. To get a match between the actual measurements and simulations, i need to de embed the effect of theseSMA. also will the unsoldered vias have any effect on the measurements?
Thanks & Regards,
Shubhangi.
Thanks & Regards,
Shubhangi.
