paulfjujo
- Joined
- Jun 9, 2008
- Messages
- 1,469
- Helped
- 298
- Reputation
- 596
- Reaction score
- 286
- Trophy points
- 1,363
- Location
- France 01800
- Activity points
- 10,639
hello
i am working with a AD9850 mounted on a break board HC-08 Q=125Mhz
i can work with this device,no problemo
but i tried to use the Reset pin5 to do a clean start
but vwhen i connect this input (to RC2 pic Output)
even i manage this output low at hardware initialisation
i get a strange behavior
On power ON, Pic & AD9850 in same time,no probleme for
initialisation,i get the sinus output ok
but, if i do a "PIC RESET" , no sinus output !
i tried to put resistor 4,7k to gnd, or to VCC to fixe voltage level
same result.
the only way i have to fix this probleme is to put Reset input to Gnd.
Question:
does someone successfully handle this Reset function on AD9850?
datasheet is not enough.detailled about this..
even for the last 2 bits control byte..w38 W39
same result.
Question:
