DDR size in vertex 4???
sobella1923
hay!! i cant figure out the size of block in this specific DDR in vertex 4, can anyone tell me what is the block size this DDR
Vertex 4 contains 64 MB of DDR SDRAM using two Infineon HYB25D256160BT-7 (or compatible) chips (U4 and U5). Each chip is 16 bits wide and together form a 32-bit data bus capable of running up to 266 MHz.
