buenos
Advanced Member level 3
- Joined
- Oct 24, 2005
- Messages
- 962
- Helped
- 40
- Reputation
- 82
- Reaction score
- 24
- Trophy points
- 1,298
- Location
- Florida, USA
- Activity points
- 9,143
There is a feature that some of the DC/DC converters have, that is to discharge the output capacitors (by the lower mosfet) when the converter is not enabled (by the enable input pin). The most common step down DC/DC (buck) converter architecture is called "synchronous rectifier", this basically has an upper mosfet (drives to VDD) and a lower mosfet (drives to GND) connected to the output inductor. The lower of the 2 mosfets is utilized by some controllers to short the output to ground before the enable is asserted (before turn on event), and after the enable is de-asserted (after a turn off event).
Some controllers seem to have this feature, while others don't. I can tell when the basic controller is turned off, its output voltage slowly decays, instead of shutting off, some cases even worse the output decays to a plateau, stays there, then decays further. The intermediate voltage can cause digital chips to malfunction, so a decisive shutdown is preferred. It can fool reset generators to de-assert an internal reset signal before VCC would become stable enough.
Years ago I saw this described in detail in a DCDC controller chip datasheet. Today I looked at some datasheets and I found no reference to whether they have it or not.
So, my question is: what is this feature called? How to find out about each new DCDC chip datasheet whether they have this feature or not.
