When you give DC input, the transformer winding acts like a resistance and you get a short circuit. Transformers function only with AC signal or pulsating DC.
normally if you in case of relay. we will ON the relay by passing DC through it then it will produce magnetic field and then it will operate. The relay is also having a coil producing magnetic flux.
In the case of transformer, EMF must be induced in the secondary. For that a changing magnetic field is required as the secondary coil is fixed. DC can provide magnetic field, but not a changing one. In case of relay, you don't need a changing magnetic field.
That's a mandatory conclusion from the differential operator in Faraday's law.that means if we place an inductor in a constant magnetic field ..we won't get any voltage...Is it right ?
what happens if we give 120v DC to a 120/12v transformer. can i get 12v DC output ?
